Ir para o conteúdo principal
Robotic vacuum released in May 2014 with various cleaning features. Repair is similar to the iCLEBO Pop, and disassembly requires only basic tools.
Error Code C2 after 2-3 mins on hardwood and carpet
How can I fix an Iclebo Art YCR-M05 that stops within a minute or two of starting to vacuum with error code C2 "Cannot detect floor" on any floor type?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@feli86116 sounds like you are getting this error based on a stuck wheel. Since iFixit does not yet have a guide for that, use something like this video to work on it. Check the drive wheels etc. Could just be a bunch of debris that is clogging things up.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Many thanks for this. I was unable to videotape my (only partial) dismantling of this unit as I don't have a "selfie" stick or any way to video such an activity without somebody else holding my phone. Apologies. I just put it back together and, unfortunately, it's "C2" error message came up just the same as before. I was, however, able to remove some dust and hair but there wasn't alot and none around the wheels....so, I'm back at square #1 ....
por
@feli86116 lets see if we can find out which sensor/wheel is responsible for that.
por
Adicionar a sua resposta
Feli será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 294
