Why is my new 16 GB DDR4 slowing down my PC?
Esta é uma boa pergunta?
This could be cause of some major software errors
Esta resposta foi útil?
OR it's because he didn't enable XMP/DOCP Profile in the bios, most of the time you have to turn it on manually as it's not always automatically set. He also never gave any details about his configuration of how it's currently setup, he didn't state whether he was adding to a previous set of sticks or if it were new all together.
Hi,
I see the RAM you bought is rated DDR4-3200Mhz.
If you enter task manager (Press Ctrl+Shift+Esc) and navigate to the performance tab and click into the Memory section, what does it say? There should be a speed section and if its set to a low value, it will slow down your PC considerably (a screenshot would also be useful)
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 88
3 comentários
Hi @boostsocia39504,
What is the make and model number of the PC or the motherboard if a custom build?
What are the specifications of the new 16GB DDR4 ram module?
How much ram is already installed in the PC?
por jayeff
8gb already installed. HX432C16FB/16 Hyper
por Boost Social Media
@boostsocia39504
Knowing the PC make and model will help to know its specs as per what amount of memory it supports etc
por jayeff
