Where can I find a new screen?
Hi does anyone know where I can find a new screen for this?
Esta é uma boa pergunta?
Hi @ethan26838
Here's the hardware maintenance manual for the laptop.
Go to p.51 to view the procedure to remove/replace the LCD panel.
Here's a link to the parts list for a 14e Chromebook Type 81MH¹.
Click on Select Commodity → LCD panels (6) to find the part numbers for all the LCD panel that can be used in the model.
Search online for the part number only applicable to your screen type to find suppliers that suit you best. Usually the part number can be found somewhere on the back of the LCD panel if you wish to verify that you're ordering the same one as the original.
¹ The Type number (or MT number) can be found on the product information label on the bottom of the laptop.
If you have a different Type number, type 14e in the search by product name etc search box and click on your Type laptop → Machine Type and then follow the above procedure to find the part numbers for the LCD panels for that model as they're not all the same I think (I didn't check all of them ;-)
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 44
