Ir para o conteúdo principal
O smartwatch de quinta geração da Apple, com conectividade celular opcional, lançado em 20 de setembro de 2019.
Destroyed Heat Dissipation Stickers
In order to remove the three display cable connectors, I completely destroyed the three pieces of extremely thin, black, heat dissipation (hd) stickers that covered each of the connections. I saw that ifixit carries a replacement hd sticker kit for the Series 6 44mm watch only. It’s out of stock so I can’t even try to adapt it for my Series 5. Is it absolutely necessary to replace the hd stickers? Is there an acceptable alternative hd sticker here on ifixit or on the internet I could use? Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The tape is EMI shielding not heat. Finding the die-cut part is very hard.
The solution is to patch up what you have. I use this tape to patch things up Conductive Copper Tape 100% Pure Double Sided Adhesive Copper Foil Tape for Stained Glass, Guitars, EMI Shielding, Electric Connections, Repairs, Grounding, Crafts (1inch x 66FT)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Happy Dad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 320
