Ir para o conteúdo principal
A versão slim do clássico Xbox 360 com disco rígido de 250 GB e Wi-Fi integrado. O reparo requer ferramentas complexas de alavanca e ferramentas especiais.
20 Perguntas Visualizar todos
Meu video game não está transmitindo imagem.
Meu video game não está transmitindo imagem. Ja troquei o cabo, ja fiz de tudo. o problema é o video game. o que eu faço?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
@davidacost60981 try the basics first:
Confirm that both your TV and console are turned on
Check that your TV is set to the correct input signal (HDMI)
Check that the HDMI cable connections to your console and to your TV are secure
Confirm that the HDMI cable is connected to the "out to TV" port on the console
Plug the HDMI cable into a different HDMI port on your TV
Use a different HDMI cable to connect your console to your TV
Connect your console to a different TV
Power cycle your console by pressing and holding the Power button for 10 seconds to turn off the console, and then turning it on again
After that try this:
  1. If there's a disc in the console, eject it.
  2. On the console, press and hold the Power button on the front of the console for 10 seconds to turn off the console.
  3. Press and hold the Power button and the Eject button until you hear a beep to turn on the console. You’ll hear one beep right away and a second beep 10 seconds later. The power light will flash on before the second beep. Don’t let go until you hear the second beep or see the console start up in low resolution mode (the Xbox startup screen will appear slightly pixelated).
  4. In either case, this will start up your console in low resolution mode (640 × 480).
  5. To change this setting, press the Xbox button  on your controller to open the guide. Go to Profile & system > Settings > General > TV & display options, and then select the resolution that you want from the options under Display. For more info, go to the article "How to change the TV display settings on your Xbox".
You can find all of this on here That is so we can rule out software and settings etc. After that we can focus on any hardware issue.
Translation
@davidacost60981 tente primeiro o básico:
Confirme se o televisor e a consola estão ligados
Verifique se o televisor está definido para o sinal de entrada correto (HDMI)
Verifique se as ligações do cabo HDMI à consola e ao televisor estão seguras
Confirme que o cabo HDMI está ligado à porta "out to TV" da consola
Ligue o cabo HDMI a uma porta HDMI diferente no seu televisor
Utilize um cabo HDMI diferente para ligar a consola ao televisor
Ligue a consola a um televisor diferente
Faça um ciclo de alimentação da consola, premindo e mantendo premido o botão de alimentação durante 10 segundos para desligar a consola e, em seguida, ligando-a novamente
Depois disso, tente o seguinte:
  1. Se houver um disco na consola, ejecte-o.
  2. Na consola, prima sem soltar o botão de alimentação na parte da frente da consola durante 10 segundos para desligar a consola.
  3. Prima e mantenha premido o botão de alimentação e o botão de ejeção até ouvir um sinal sonoro para ligar a consola. Ouvirá um sinal sonoro imediatamente e um segundo sinal sonoro 10 segundos mais tarde. A luz de alimentação acende-se antes do segundo sinal sonoro. Não largues a consola até ouvires o segundo sinal sonoro ou até veres a consola a arrancar no modo de baixa resolução (o ecrã de arranque da Xbox aparecerá ligeiramente pixelizado).
  4. Em ambos os casos, a consola será iniciada no modo de baixa resolução (640 × 480).
    1. Para alterar esta definição, prime o botão Xbox  no teu comando para abrir o guia. Vai a Perfil e sistema > Definições > Geral > TV e opções de visualização e, em seguida, selecciona a resolução que pretendes nas opções em Visualização. Para mais informações, consulta o artigo "Como alterar as definições de visualização da TV na tua Xbox".
Podes encontrar tudo isto em Isto é para podermos excluir software e definições, etc. Depois disso, podemos concentrar-nos em qualquer problema de hardware.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Davi da Costa Sousa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 23
Duração total: 152
