What is the size of screw bolts?
What is the size of screw bolts of Lenovo ideapad 100-14IBY
Esta é uma boa pergunta?
@jaelouieta21349 there are quite a few different screws and you are not being specific to which part you are referring to. Since the question was left as an answer to a different question, which dealt with a bottom cover, I can tell you that the bottom cover uses (7) M2 X 6mm and (2) M2.5 x 5 mm
For all the other screws use the Hardware Maintenance Manual for your computer. All screws are listed in that.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 15
