Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the second generation Sony PlayStation 5 DualSense controller. Identified by model number CFI-ZCT1W and motherboard model BDM-020.
20 Perguntas Visualizar todos
Headphone port removal and replacement
Hey does anyone have a video on how to remove and reinstall the headphone jack, I can see 4 solder points around it but my iron gets too close and just melt the plastics, same with the hot air gun. Any suggestions, thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Flux it, use "Low Melt" solder, and lower the temp on the iron. After a little time the port/jack should just fall out. Wick away the old solder, solder in the new jack using 60/40 leaded solder.
Wait......by "melts the plastics" do you mean the controller shell?? O_o
Always remove the board from the shell before hand. :)
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hey thanks for the response. Not not the shell, I take the board completely out, I meant the headphone port plastic itself. I will try what you said. Thanks.
por
Adicionar a sua resposta
Jordan Shaw será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 26
Duração total: 321
