Why MY pc unable to turn on?
How can I turn on my PC?
Esta é uma boa pergunta?
What happens when you press or hold down the power button in the Top Right corner right of the delete key above the backspace key?
Is the computer charged?
If you hold down the power button and the screen turns on OR the keyboard turns on then the computer should be on. If it seems to be on but it only shows the Dell logo or (screen on/keyboard on) then press the "F2" key at the top of the keyboard repeatedly until the bios screen opens. Then from there, I'm not completely sure on the correct way to help your problem but resetting the BIOS might help.
Steps the reset bios (to default, not resetting the CMOS or NVRAM) (from Dell website)
This will help
for your device at iFixit. Whatever you do, please be sure todispose of your battery properly.
Dell Laptop Won't Turn On - iFixit Troubleshooting
Also, the fix I showed earlier "reset's" the Bios but DOESNT reset the CMOS or NVRAM, so
How to clear the BIOS, CMOS, or NVRAM on Desktop computers without an RTCRST Jumper or serviceable Coin Cell battery
If your desktop computer was produced before April 2020, the computer most likely has a jumper-based reset. Desktop computers manufactured after April 2020 use the RTC Reset ability.
Note: Desktop computers released after April 2020 should have RTC Reset enabled by default.
For desktop computers that use RTC Reset, hold the power button for 30 seconds.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Ao todo: 116
@yegilituboshoka Does it show you any sign of life? Any LED that comes on? What have you checked? Did anything happen to it prior to this?
por oldturkey03
