How do I fix my phone?
My phone shut down for no reason . Then when he turned on , I was stuck at the SAMSUNG GALAXY Power by android. What do I do?
Esta é uma boa pergunta?
@ilijastefanovic first thing to always try is a soft reset. Hold the Power button until your phone shuts off, wait 30 seconds, and then turn it back on.
After that, try to start your phone in safe mode. See if that responds.
Last resort is a factory reset:
Please follow the instructions below to factory reset your Samsung in recovery mode if you cannot access your phone’s factory reset options in regular mode.
You may have to reflash your software with Odin if none of this works.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 80
Duração total: 384
My Samsung A54 is showing Samsung galaxy logo on the screen without process more than position, once you charge it, it will display Samsung and remain there. Please I need help please.
por Amosjack1
@amosjack1 check the steps in the given answer. This seems to be a software issue and could be your firmware "You may have to reflash your software with Odin if none of this works."
por oldturkey03
