Ir para o conteúdo principal
O RCA Cambio é um tablet Windows dois em um produzido pela RCA.
Sound doesn’t work
I turned on my tablet but there was no sound. Restarting it did nothing. How do I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
First, make sure your volume is turned up, and that no headphones or speakers are plugged in. If sound does not work, try these things and report results: Does the sound work via headphones with either bluetooth or the headphone jack? Check and make sure that the audio output in windows setting is set to the right source. If problems still continue, you may need to replace the speaker(s).
Esta resposta foi útil?
Pontuação 1
1 comentário:
The headphones don't work. When they're unplugged, the speakers don't work, and the tablet doesn't say any speakers are connected. How do I replace the speakers?
por Compartilhar
Adicionar a sua resposta
profile será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 44
Ao todo: 377
