Ir para o conteúdo principal
Repair information for the Apple Universal Dock Model A1256. Released ~2010.
5.5 Gen iPod classic not working with the remote
I have this dock for my "hi-fi" system and bought a remote on eBay for fun. The remote works fine with an iPod mini (flash modded), 4th gen (flash modded), 1st gen nano, and 3rd gen nano. My 5.5 gen (flash modded) plays and charges just fine through the dock but the remote does not work with it. I know this is a very nit-picky problem but if anyone has any solutions I would love to try them out!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@garybuchanan there was a revision of the dock connector between those models. Your iPod Classic may not respond to your remote because of that. I remember that there were the same issues with some Bose docks for the same reason.
Of course, it is also possible that this is related to some missing firmware etc. After all "The remote control, iTalk and other serial devices use the Apple Accessory Protocol for communication with the iPod. This protocol was introduced with the 3rd generation iPods, and is also compatible with the 4th generation iPods and mini iPods. The connections uses a standard 8N1 (one startbit. 8 data bits, one stop bit) serial protocol, 19200 baud (higher rates up to 57600 are also possible, but speeds faster than 38400 may cause problems with large amounts of data), with a delay of 12 microseconds inserted between the end of the stopbit and the beginning of the next startbit (also works without this delay)." from here
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thank you for the info! Still, it’s strange to me that it works with a 3rd gen Nano (released 2007) and not my 5.5 gen (released 2006). Maybe the firmware or that it’s a user-modified 18 year old device can be to blame
por
Adicionar a sua resposta
Gary Buchanan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 24
Ao todo: 408
