Ir para o conteúdo principal
iPhone kernel panic while charging
I bought an iPhone 11 Pro second hand. It had only one problem which did not bother me much. While charging, sometimes it would stop, or end up in a rapid charge/no charge loop until settling down and not charging. It would not always happen, but was much more likely when I was using it while it was charging.
Today while charging, I encountered my iphone restarting and I also got a kernel panic log. I hav eno idea if it was due to the charging or just a software glitch.
What may be the culprit?
Here is a excerpt fron the panic:
{"bug_type":"210","timestamp":"2024-01-08 21:16:12.00 +0100","os_version":"iPhone OS 17.1.2 (21B101)","roots_installed":0,"incident_id":"D6B8935D-980A-4DB8-8F71-8C6313F84824"}
"build" : "iPhone OS 17.1.2 (21B101)",
"product" : "iPhone12,3",
"socId" : "8030",
"socRevision" : "11",
"incident" : "D6B8935D-980A-4DB8-8F71-8C6313F84824",
"crashReporterKey" : "c2f1c2498727560b9deef40ac5ef8d9249a4e40c",
"kernel" : "Darwin Kernel Version 23.1.0: Tue Oct 10 02:21:48 PDT 2023; root:xnu-10002.42.9~2\/RELEASE_ARM64_T8030",
"date" : "2024-01-08 21:16:12.75 +0100",
"panicString" : "panic(cpu 3 caller 0xfffffff013dc0d1c): \"apcie[3:baseband-pcie]::handleInterrupt: AF\/Link timeout linksts=0xab000000 pcielint=0x0000c000\\n\" @AppleT803xPCIePort.cpp:1379\nDebugger message: panic\nMemory ID: 0xff\nOS release type: User\nOS version: 21B101\nKernel version: Darwin Kernel Version 23.1.0: Tue Oct 10 02:21:48 PDT 2023; root:xnu-10002.42.9~2\/RELEASE_ARM64_T8030\nFileset Kernelcache UUID: D185293FD8343D8F9472BB1529F7C545\nKernel UUID: 07C490B9-EF6D-381D-94E6-D96049CEF980\nBoot session UUID: D6B8935D-980A-4DB8-8F71-8C6313F84824\niBoot version: iBoot-10151.42.2\nsecure boot?: YES\nroots i
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
baseband issue or power management chip
Esta resposta foi útil?
Pontuação 2
1 comentário:
Actually, I have not experienced this problem for 5 months (since I bought it). The battery is not draining fast and it is at 86% of its original capacity. I do not experience problems with making phone calls. It could still be the fault of the power management chip?
por
Adicionar a sua resposta
Ali Baby será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 439
