Ir para o conteúdo principal
O Samsung Powerbot R9250 é identificado pelo número de modelo R9250. Foi lançado em 2018.
Error code C03 shows up everytime
what should i do? The thing doesn't even follow any route anymore it just goes wherever it wants
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I've had this issue. To clarify the answer below, I seem to get items stuck behind the wheel/ square lug which attaches to the gearbox. The below youtube video shows taking it apart. You can also order a replacement wheel assembly as the motors do appear to start going out as well (and there isn't an easy way to get them).
https://www.youtube.com/watch?v=8jQlBv0e...
por Compartilhar
Adicionar um comentário
1 resposta
The C03 error code on a Samsung POWERbot indicates that something is caught in the right driving wheel. You can clear the error by clearing the obstruction.
  1. Turn the power switch off that is located at the bottom before cleaning the robot.
  2. Use a blunt rod or tweezers to remove any foreign matter.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lee Guang será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 59
Ao todo: 1,217
