How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
Esta é uma boa pergunta?
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
Esta resposta foi útil?
It does not appear to be enough room to use the pin driver.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 2,180
