Display cannot be replaced
Hello, i tried to replace my cracked display. When sliding the display unit up there was still metal frame on the main unit. I know i do not have a genuine display installed so could it be that the preowner just glued it in with the wrong glue? Or can i still remove the metal frame with force? Thanks
Esta é uma boa pergunta?
4 comentários
did you remove the pentalobe screws on the bottom of the phone, if yes then use a hair dryer to heat the adhesive under the metal plate and try lifting it up
por daniel
Thanks Daniel. Yes, i did. I was suprised the metal plate stayed on , but i could easily open the display.
I will do it according to your recommendation and will heat it up to hopefully separate it
por Philipp Schneider
Ok. It really worked. Thanks a lot for your answer!!!
@philippsch91253 glad you got it sorted
por daniel
