Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Wired Connection not working
I have a ds4 controller that works via Bluetooth but is unable to work with a wired connection to the PlayStation and pc. I figured the port wasn’t working so I decided to swap the port with another controller whose analog sticks are broken. This new port works perfectly but when making the swap, the controller still doesn’t show up as a wired connection.
I can provide pictures or answer any questions to help troubleshoot this issue. At this point I’m more intrigued on how to get it working than anything else. Any hardware that I should be looking at that could be the culprit here?
Worth noting: Since the wired connection wasn’t working, i decided to download ds4windows to see how the Bluetooth connection to the pc would hold up vs input lag. During this process, I was changing settings on ds4 along with the controller device in my pc control panel. I disabled a driver that a video recommended during this. Not sure if I might have done something to alter the controllers ability to recognize the wired connection.
Thank you!
Update (01/07/24)
This has been solved. Needed to get the correct usb connection for the controller model. Ordered this online and now the controller works fine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
@lincolnabe0978 copy your update as an answer, then accept it. That way we know it has been resolved.
Pontuação 1
Adicionar a sua resposta
Brad Riley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 30
Últimos 30 dias: 98
Ao todo: 2,164
