Ir para o conteúdo principal
Aspirador e vassoura sem fio leve para recolher migalhas e outros resíduos pequenos.
Will Not Start when power button pressed
When power button is pressed, green light turns on but sweeper will not start
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
same thing happens with mine. It knows it is charged because when you plug it in for charging it flashes red then quickly realizes that the battery (voltage) is full. When you press the power button the green light comes on, but no reaction from the motor itself. When I have time, I will open it up and see.
por
Adicionar um comentário
1 resposta
Finally figured it out…
Look inside the part that battery goes into and you will find 2 small holes on bottom ..
Use a small screwdriver in each hole and tighten screws well.
Put battery in and turn on ..it should work..if it stops and starts remove battery and try to tighten those 2 screws again
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Thomas M Ray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 40
Ao todo: 576
