MX master shell replacement
Can the shell of a Logitech MX master 2 or 2s be a replacement shell for the Logitech MX Master?
They both physically look the same, use the same charging ports and have similar dimensions.
Esta é uma boa pergunta?
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 317
After a bit of digging, the top shell of the Master 2/2S can be used for the MX Master. However the bottom shell, Master 2S and 2 has not got the circular connect button therefore cannot be transfers over - you will have to use the original one.
por Wow Compartilhar
