The system clock gets reset.
Whenever I shut down my laptop, the system clock gets reset. What could be the reason and please suggest the solution.
Esta é uma boa pergunta?
The coin cell RTC battery (Real Time Clock) connected to the motherboard has failed and needs to be replaced.
This battery maintains the time and date and all the BIOS settings when the laptop is turned off. It is a non rechargeable Lithium coin cell battery and usually lasts for 4-5 years
Here's the maintenance and service guide for the laptop.
Go to p.50 to view the procedure to remove/replace the RTC battery
Search online for 486835-001 to find battery suppliers that suit you best.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 33
Ao todo: 323
1 comentário
revisa la batería que está al lado del disco duro que viene conectado a la placa, lo mas seguro es que este mala por eso es que se reinicia por eso tienes atrasada fecha y hora.
por ALCIDES RAUL HERNANDEZ MACHADO Compartilhar
