Ir para o conteúdo principal
Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Bad screen or flex cable?
Hello!
Everything was working fine until one day i turned on the Mac and vertical coloured lines appear on the display.
Nothing change no matter the angle of the display.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
As a sanity check, you should plug in an external monitor. That will let you verify that it's a screen issue and not a GPU problem. Let us know what you see.
por
Adicionar um comentário
1 resposta
Sorry to say this is a classic case of a messed up display assembly. Here’s the needed partMacBook Pro 16" (2019) Display Assembly And here’s the guide MacBook Pro 16" 2019 Screen Replacement
Imagem de Replace a display compatible with a model A2141 2019 16" MacBook Pro laptop. Includes the 3072 x 1920 LCD screen, display cover, bezel, FaceTime HD Camera, and clutch hinges.
Produto
$444.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Neacsu Alexandru será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 148
