Why does the projector shut off?
Turning on the projector results in all proper sounds and good picture. After a short period of time the unit shuts off and can be restarted. No error leds are present.
Esta é uma boa pergunta?
After some investigation, found that the lamp cover switch was the culprit. There are points inside the switch that needed to be cleaned because of burning from arching because the switch is not available. I think someone else was already in there as the springs appeared to be installed backwards. Now I have to find out why I have no blue background.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 279
1 comentário
@andydavis38123 Has the fan been cleaned out? Has any thermal paste been replaced?
por Andrew S
