Ir para o conteúdo principal
The JBL PartyBox 300 is a large, powerful Bluetooth speaker that delivers rich sound with a selectable bass boost. It features an integrated light show with various modes that sync to the music. The built-in rechargeable battery provides up to 18 hours of playtime. The JBL PartyBox 300 became available for purchase in October of 2018.
Power Button is staying an Amber Red with plug and without
[While pressing the power button it will not switch over to the white and show the battery level. Even if you reset the speaker the power button will go dark, then when plugging back in the power button goes back to amber red. Also will not even show charging. Even if you don't plug in and press the power button it goes to Amber color.
Yes Battery is good and I even swapped out for a new one and same results.
Here are pics
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@chris58709 anything happened to it prior to? What have you checked? from the brief description it appears that this is focused mostly on the power board. If you can, post some good pictures of all of the boards with your Question. Let's see what the battery looks like as this could be at fault as well. Adicionar imagens a uma pergunta já existente
Update (12/24/23)
@chris58709 could just be my old eyes but what you got going on here?
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Chris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 22
Ao todo: 691
