Ir para o conteúdo principal
O aspirador vertical sem fio Shark Navigator Freestyle oferece portabilidade e fácil manuseio. O aspirador pode ser identificado pelo número do modelo SV1106 e pelo seu formato elegante.
Need replacement for Front wheels
Both tiny front wheels are falling apart. Where can I get replacement parts for that. I saw replacements for the back wheels and for other shark vacuums. Just not for this particular machine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Kimberly,
I honestly didn't have any more luck than you did in finding new replacement parts; the closest I came was a listing on eBay for one that is new but it's really selling the accessory door with the wheel on it, so it's only one. There are a few used ones you can get there, the search I used was "Shark SV1106 (wheel, wheels)".
Shark SV1106N SV1110 SV1100 SV1112 BRUSHROLL ACCESS DOOR SMALL WHEEL OPEN BOX
However, those wheels look an awful lot like the ones I bought for my Navigator Lift-Away. If you have a set of calipers or are really good with a ruler, measure yours and compare them against this picture that came from the listing I bought from.
Imagem
I saw at least one post where someone mentioned that the wheels themselves worked fine but the post that came with them was the wrong size so they just used their own original ones. Here's the listing.
Amazon.com: Front Wheels for Shark Vacuum Cleaner, Replacement Wheels Compatible for Navigator Rotator Series NV22, NV42, NV352,NV360,NV350, NV351,NV355, NV356e, NV370, NV502,N472, NV650w, UV440, nv502, nv752 : Home & Kitchen
That seems about the best I can come up with, hopefully it'll help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kimberly Idleburg será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 21
Ao todo: 931
