@robsonflud explain this a but better. Not quite sure what you did. I am certain this is just getting lost in translation :-)
"double vision" is usually caused by the main board followed by the T-con board. T-con board. since your display is still visible, try to access the Self-Check Diagnosis History.
VIEWING THE SELF CHECK DIAGNOSIS HISTORY
When an error is detected, the Self Check screen records the number of times the error occurred. This is helpful in confirming past occurrences of an error and for determining if an error is intermittent when the customer is not sure what is causing the television to shut down. If the screen displays a “0”, no error has occurred.
1. Press POWER to turn on the TV and then turn it off again.
2. Press the following buttons on the Remote Commander within 1 second of each other:
DISPLAY==> Channel 5==> Volume - ==>POWER
Once it shows you the history, take a picture of that and post it with your Question. That might give us a hint.
Since this becomes more visible when your TV has been on for a few minutes, this could be a Video processing IC error on the main board. Check that for excessive heat.
It will be helpful if we can see your circuit boards. Unplug the TV and remove the back cover. Than take a well focused picture of the complete setup. After that a couple of good pictures of the boards.
In the meantime the only other thing I can offer is the service manual for the model. It is a RB1G chassis and here is the manual. It is written in Spanish but I do hope that it will still help you.
Translation
O @robsonflud explica isto um pouco melhor. Não sei bem o que fizeste. Estou certo de que isto se está a perder na tradução :-)
A "visão dupla" é normalmente causada pela placa principal, seguida da placa T-con. Placa T-con. Uma vez que o ecrã ainda está visível, tente aceder ao Histórico de diagnósticos de auto-verificação.
VISUALIZAR O HISTÓRICO DE DIAGNÓSTICO DO AUTOCONTROLO
Quando é detectado um erro, o ecrã de auto-verificação regista o número de vezes que o erro ocorreu. Isto é útil para confirmar ocorrências anteriores de um erro e para determinar se um erro é intermitente quando o cliente não tem a certeza do que está a provocar o encerramento do televisor. Se o ecrã apresentar um "0", não ocorreu qualquer erro.
1. Prima POWER para ligar o televisor e, em seguida, desligue-o novamente.
2. Prima os seguintes botões do Comando à Distância no espaço de 1 segundo entre si:
DISPLAY==> Canal 5==> Volume - ==>POWER
Assim que o histórico for apresentado, tire uma fotografia e publique-a com a sua pergunta. Isso pode dar-nos uma pista.
Uma vez que o problema se torna mais visível quando o televisor está ligado há alguns minutos, pode tratar-se de um erro do CI de processamento de vídeo na placa principal. Verifique se há calor excessivo.
Será útil se pudermos ver as placas de circuitos. Desligue o televisor e retire a tampa traseira. Em seguida, tire uma fotografia bem focada de toda a instalação. Depois disso, tire algumas boas fotografias das placas.
Entretanto, a única coisa que posso oferecer é o manual de serviço do modelo. Trata-se de um chassis RB1G e aqui está o manual. Está escrito em espanhol, mas espero que vos possa ajudar.
MANUAL DE REPARACIÓN RB1G
Adicionar imagens a uma pergunta já existente
