Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Xbox 360. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Xbox 360.
How to fix error (0011)?
referring to oldturkey's answer,
I held down the eject button and the sync button and got the error code
(0011) meaning it is a problem with the CPU. Any suggestions for fixing a problem with this error code??
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsink screws are tightened securely to the board/heatsink holes. This error appears when the CPU overheats. The heat can't be dissipated to the heatsink and/or the heatsink isnt cooled properly. This can be caused by improper thermal compound usage or if the error comes up instantly while booting the console, the heatsink will likely not be making any contact at all with the chip. In rare cases it can also be a faulty temp sensor. From here and here for more info. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Connecting to device ...
Repairing UFSx...
FAILED: Repair UFSx failed, ErrorCode:0011
Update error may be caused by instability of communication, please try the following methods to resolve:
1. Click the "Prev" button,select "Repair UFSx first" and re-update.
2. Replace a USB data cable, and then re-update.
3. Replace a host computer USB port, and then re-update.
If the above solution to the problem remains unresolved, please contact our technical support.
por
Not sure if your still active oldturkey but you described my problem exactly near the end. Could you update your links by any chance?
That info is where I need to go for my next step.. either way thx!
por
@Bobby Handley let's see if I have more info on this. Of course it's 10 years old so could be tough:-)
What are the exact issues with your Xbox?
por
Adicionar a sua resposta
Randy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 13,119
