Ir para o conteúdo principal
Nintendo Game Boy Advance, lançado em 2001. O reparo requer apenas ferramentas comuns e não necessita de calor.
Very dark screen when playing games
I’ve just purchased a second hand game boy advance and it’s quite hard to see the game due to dark screen. I’ve tried the usual holding select and clicking left/right but no good. Also found the pot behind the serial number but no good unless I need a very small screwdriver but not sure. Any help greatly appreciated
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The Game Boy Advance doesn't use a backlight, which can make it hard to see the screen in low-light conditions. If you are willing to take apart the GBA and use some tools, there many backlight modifications on the web that can be used to help install a backlight into your GBA. But you must keep note: by installing a backlight mod into the GBA, you must do it correctly, as you could cause damage to your GBA if done incorrectly. You will need some tools, and a soldering iron, for the task.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Lee Wheller será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 73
Ao todo: 2,673
