Ir para o conteúdo principal
The "Outback" name has been utilized on two different Subaru branded vehicles. One of these models is based on the mid-sized Subaru Legacy and the other derived from the hatchback version of the Subaru Impreza.
Power windows dead, no response.
All the power windows are off on all passenger side. The driver side power window is the only window still works. What's wrong? Fuse?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi @ankeaux,
What year model is the vehicle?
por
Adicionar um comentário
1 resposta
Checking the fuse/circuit breaker is the first step. If that's good, check for power coming into the master switch on the driver's door. If you don't see power, check for a broken wire in the door hinge area.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
AnkeauX será eternamente grato(a).
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 8
Últimos 30 dias: 17
Ao todo: 162
