Ir para o conteúdo principal
How do I fix a F-7 E-1 error
Update (11/26/23)
Update (11/26/23)
All of those symptoms plus this lock activates and don't release for an hour. It's an Amana top load, model NTW4516FWR.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@matthewwenner what exact model is your washer? What have you checked? On some Whirlpool washers the F7E1 error is a basket speed fault which is displayed when the main control cannot determine speed of basket, or speed changes too quickly.
por
@matthewwenner currently working on the same model washer with a F8E1 error. Let us know what the diagnostics show.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @matthewwenner
Here's the Tech Sheet - W10740573 - Rev B for the washer.
See p.7 for what to check for an F7:E1 fault code.
Run the diagnostic checks to make sure what error code is being shown. See p.2 for how to initiate the tests and p.3 for how to interpret the error status lights
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Matthew Wenner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 1,094
