Ir para o conteúdo principal
The Dell Latitude 3510 is a laptop for business released in 2021. This guide assists with repair of the laptop.
Replace a cracked screen
Please help with the steps on how to replaced my cracked screen. Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @tinobeatz
Here's the service manual for the laptop.
Go to the bottom of p.64 to view the procedure to remove/replace the display assembly.
There are different LCD panels available for the laptop as can be seen on this website.
To ensure that you're getting the same replacement panel search for the Dell part number (usually found somewhere on the back of the panel itself- after it is removed of course e.g. T1WD3 or H4V09 etc) to find suppliers that suit you best.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tinobeatz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 249
