Acer VN7-571G - turning off by itself without warning and doing a rest
Hi. I'm new here and I'd like to ask something about one of my laptops, the "VN7-571G", which is behaving abnormally. It turns on and I can use it for a while. I upgraded the hardware of the laptop to be more responsive and reliable, but it turns out that it's not reliable at all. It originally had 8GB of RAM, a 1TB hybrid SSHD and a WiFi 5 card. I upgraded the RAM to 16GB, installed a 128GB SSD and instead of the SSHD, I installed a normal 2TB HDD for files. So far so good. Then I cleaned up the fans and replaced the thermal paste with some fresh Arctic MX-4. Proceeded to upgrade the WiFi card and installed a Intel WiFi AX200, which works perfectly fine as well. But..
The laptop turns off for some reason as if it would not get enough power. The battery was old so I got a brand new battery to replace that as well, but yesterday it did the same thing again! Even with the new battery.. And it ridiculously showed me 76% of battery wear level after turning off and and on again! (which was the same wear level it had with the previous battery, but sometimes it showed 13% as well)
And now the laptop simply does not work reliably. It simply shuts off without any warning. Just like it would be a restart, but without warning. I don't really know what to do next. I didn't damage anything on the board as I'm sure that I have disassembled 800+ laptops, for repairing and/or cleaning the inside. But I don't have any information on what could cause that issue. I mean.. if it would overheat, it wouldn't turn on again instantly after it shuts down, right? And why does it still think that the battery is "bad"? The battery wear level fluctuates from 0% to 75%, this is really the first time I'm experiencing something like that.
Do you guys have any ideas?
Then please let me know!
Regards,
Emre
Esta é uma boa pergunta?
2 comentários
Exactly got the same problem for my client's laptop. Have you fixed this issue? Thanks
por jolooo myke
Hey there, I fixed this issue by changing the battery. The battery was causing problems with charging, it was a no name battery, replaced it with a high quality branded cell, also replaced the RAM (2x8GB) as it was one of the replaced parts. (replaced them earlier and after that it started to behave like this..)
It works perfectly fine now and the customer is happy with it. Hope that helps.
por Emre
