Packard Bell EasyNote LK (VAB70) - blue LED but not display
Hello, I have a Packard Bell EasyNote LK (VAB70) laptop that is not booting.
It does charge the battery (red LED); when I press the power button there is a blue LED, the DVD drive moves, after a while the fan is spinning but that's it.
I tried a few things:
- reseat the screen connectors (both behind it and on the motherboard)
- remove the DVD drive, HDD, wifi card, coin battery
- reorder the RAM sticks - both work fine on another laptop and checked with Memtest86+
- connect an external monitor (HDMI and VGA), with and without the LCD panel connected
- shine a light in case the backlight was dead
I don't have its history; the motherboard does not seem to have water damage, what else could I try?
Thanks
Esta é uma boa pergunta?
Hi @misscat,
Did you try to reset the BIOS by removing the main battery and the RTC coin cell battery and then press the Power button for 30 seconds, reinsert the RTC and main battery etc and check if you can get into BIOS OK with a display - press F2 on startup?
por jayeff
@jayeff I tried your instructions but the screen is still blank, I guess it means there is an issue with the BIOS?
por MissCat
@misscat
BIOS or motherboard.
What is the model number of the motherboard, (printed on board itself)?
Without knowing its history it will be difficult. Does it have a removable CPU? It could even be a faulty CPU who knows
Knowing the motherboard model number may help to find the schematics (if hardware) and the BIOS.bin file (if software) to find out what's wrong
If software you will need a programming tool to reflash the BIOS chip.
por jayeff
@jayeff sorry for not replying sooner - I was able to reflash the BIOS chip (unfortunately downloaded from unknown sources, the Asus website has nothing to download for this model). I tried with v1.03 and v1.10 but still nothing.
The CPU is soldered; here what's written on the motherboard:
AAB70 MAIN BOARD
REV:2.0
P/N:08N1-0NW3J00
por MissCat
