Is it possible to do that
Hello
Is it possible that we can put one 11 pro max face id or the whole thing with the dot matrix to other 11 pro max.
Esta é uma boa pergunta?
Hello
no face id is paired to the phone
Esta resposta foi útil?
No even with the programmer the i2c
@umerabubakar the i2c is for programming a flex instead of doing jumpers etc it blows the old component but its still the original face id, what is wrong with the original face id module ?
The phone fell, after that it was showing that face id is not available
When i go to settings try to set it when I click on get started i says face id not available.
That means i can add the other face id module to my phone if i do it with the programmer.
Like i can copy the data from the face id module from the original phone and then i can erase the data on the (2 module) and rewrite the original module data in the (2 module) with the programmer
@umerabubakar no you cant programme a new module, have the old 1 repaired
Or you know who can fix it in Mississauga
My budget is 90$
im in the uk, you could try here https://microscancomputers.com/
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 46
1 comentário
Is (face id not available) and (a problem has been detected in the true depth camera) are same problem
por Umer Abubakar
