Ir para o conteúdo principal
Guias para a versão Wi-Fi do iPad mini 5—modelo A2133. Lançado em março de 2019, o iPad mini 5 é o sucessor do iPad mini 4.
Replacement Battery Zero volts
Hi, my wife’s 3y/o iPad mini 5 died the other morning. Wouldn’t startup, wouldn’t charge.
I tried all the online suggestions but no joy.
I decided to replace the battery but first I removed the old one (partly to check my ability to do this ok) and found it at 0 volts.
So I ordered a new one and, before fitting, was surprised to find it also at 0 volts.
I wouldn’t have been too surprised but the spare battery I had ordered for my own iPad mini 2, two years ago, was still showing 3.5 volts.
However, the battery seller encouraged me to fit it and charge the device. I did this but no joy.
My real question is; “would you expect a NEW battery to arrive CHARGED?” ie. Is it possible I’ve been sold a dud battery?
Many thanks!
Kind regards, Mike.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
That battery is permanently damaged. It would be nearly impossible to restore a battery in that state of charge. Personally would keep pressuring the seller for a refund and get the battery from a more reputable place like here at iFixit or another place.
Esta resposta foi útil?
Pontuação 1
4 comentários:
Many thanks Duck, I’ve got the refund and reordered through iFixit!
Much appreciated
por Compartilhar
@mikefloutier No problem. Glad to help.
por Compartilhar
Hi, it’s me again. I received your replacement battery and installed it but it still won’t start.
I’m now looking for other repair ideas.
por Compartilhar
@mikefloutier best way to do that is by creating a new question. There, give all the details, background of the iPad and everything you have done and tried.
por Compartilhar
Adicionar a sua resposta
Mike Floutier será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 36
Ao todo: 589
