Ir para o conteúdo principal
The HP 6530b is a Notebook PC is a 14.1-inch laptop computer that was released either with an anti-glare display or an HP BrightView display.
11 Perguntas Visualizar todos
Window dose not turn on but power button has light
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
My laptop is not working
por
@mohammadamaan exat make and model for your laptop? We need to know what it does do when you plug it in and try to turn it on. WE need details.
por
Adicionar um comentário
1 resposta
@kapilbansal let us know if you see the HP screen coming on when you start the computer. You also need to try and access the BIOS to check if our computer finds its hardware, like the HDD/SSD. Next you want to connect an external monitor to ensure it is not your LCD screen that does not work. Let us know what you already checked out. HEre is the SM for your computer which will help you to work on it Compaq 6530B Maintenance And Service Guide
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kapil bansal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 90
