How do I tell if the battery is receiving charge current,
Nin. Sw. Lite is not responding to charging. I have the back shield off, is there a set of contacts to the battery that I can monitor with a DVM - to see if when the charger is attached and powered that the voltage is higher than w/o the charger attached.
Esta é uma boa pergunta?
1 comentário
@jgbsr I assume that you are referring to a Nintendo Switch Lite
por oldturkey03
