Ir para o conteúdo principal
This unit cools or heats the water it circulates through the ChiliPad mattress pad. Model: CP-CUBE
Anyone know thermistor part details?
Does anyone know the specs or replacement part on the thermistor? Mine went bad and I've currently just wired in a resistor to keep it working, but I'd like to be able to control the temperature again with a working thermistor.
Tech support on their end wasn't helpful. :(
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Took a gamble Amazon and found a workable one:
https://www.amazon.com/dp/B07LGMXTKK
Description:
uxcell 2 Pcs 10K NTC Thermistor Probe 15.7 Inch Epoxy Sensitive Temperature Temp Sensor for Air Conditioner
I think the main thing is just finding a 10K NTC thermistor that is waterproof (thus Epoxy in this case).
After putting it in, water temperature was +/- 1 degree off what my thermapen registered. Not bad for $5.49 for two of them!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jerry Stevenson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 159
