What precision screwdriver bit set to purchase to remove hard drive
want to remove hard drive. what precision screwdriver set should i purchase for the job
Esta é uma boa pergunta?
Here's the ifixit PowerBook G4 Aluminum 15" 1.5-1.67 GHz Hard Drive Replacement guide that will help.
In the What you need → Parts box click on Show more to view the tools necessary to do the task
Esta resposta foi útil?
Sadly this system uses a PATA drive interface so you will need another Mac system which supports PATA (IDE) natively or via a PATA to SATA adapter to retrieve the data on the drive.
thank you for your help. i was able to remove the hard drive.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 58
