Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Should I be worried if I accidentally poked the battery?
I poked the phone battery during a replacement with the tweezers available in the kits. It left a tiny hole. Should I be worried and replace it. I didn’t notice a strong chemical smell.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
@jeangabriel5999 possible that you only poked through the outer package. You could cover that with a piece of electrical tape. Since we do not know how deep etc. and to remove all doubt, replacing the battery will give you a sense of security that it is now fixed. :-)
Since you have it already open and since you do seem to be concerned about it, go ahead and replace it. One less worry.
iPhone SE 2020 Battery Replacement
Imagem de Replace a 1821 mAh battery compatible with an iPhone SE 2020. This replacement does not require soldering.
Produto
$24.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jean-Gabriel Grimm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 114
