Ir para o conteúdo principal
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
20 Perguntas Visualizar todos
Frigidair combo dryer starts and stops after a few seconds.
Model FLCE7522AW frigidair combo dryer starts and stops after a few seconds without any sounds or beeps. What can it be? Washer works perfectly fine.
Esta é uma boa pergunta?
Pontuação 1
5 comentários:
@krystalcol57696 at what point does it turn back on? Immediately or do you have to wait a while? What have you checked? Could be a failed thermostat etc.
por
It does not turn back on once it has shut off, only turns back on if I press the start button again and then shuts down again after a few seconds.
por
Mine does the same thing. Is there a picture or a diagram of where the thermostat and fuses would be located?
por
Mine does the same thing. Is there a picture or diagram of where to find the thermostat and fuses? Model FLCE7522AW3
por
Most dryers would have a similar schematic. There are thermal cutouts in a dryer but no fuses. See my above comment.
por
Adicionar um comentário
1 resposta
Is there any sign of heating? It could be a high limit thermo. It could be a problem with the heating coils.
Esta resposta foi útil?
Pontuação 0
1 comentário:
No :-( since it stops just seconds after starting, there is no sign of heat.
por
Adicionar a sua resposta
Krystal Colon Maldonado será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 170
