Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 6 do Google, lançado em outubro de 2021. Identificado pelos números de modelo GB7N6 e G9S9B16.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Did old screen work? I have the same issue touch is not working even though there is no crack
por
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
por
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
por
Adicionar a sua resposta
Mike Meller será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 41
Ao todo: 2,366
