Ir para o conteúdo principal
Repair for speakers, stereos, header units, and CD players for your car or truck.
20 Perguntas Visualizar todos
pioneer mvh-s622bs notification
I have a pioneer mvh-s622bs and I keep randomly getting a "Connection notification with main unit: connect to main unit?" Notification on my phone while my car off. Why and should I worry about my radio turning on while my car isn't?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @wilburchfield,
If the phone is connected to the radio using Bluetooth (BT) then if you're receiving notifications on the phone and the car is >33' (10m) from the phone then the Pioneer app? in the phone may be sending the notification, because the car is out of range and presumably the radio is turned off, so it can't connect. You won't be receiving anything from the radio
Perhaps check the settings in the app or try turning off BT in the phone and see if the notifications stop.
Quick way to tell depending on the time interval between the notifications is to sit in the car with the unit turned off and check if you still get the notifications and check if the radio has turned on or not.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Wil Burchfield será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 58
