Ir para o conteúdo principal
This is the Intel variant of the Lenovo IdeaPad Flex 5 it has a Intel (R) Core i5 1035G1 it also has Intel (R) UHD graphics or Iris Xe graphics on the 5i model.
How to fix charging port
My laptop fell on the corner where the charging port is and it damaged the hinge too.
Just looking for a guide to replace the charging port as the laptop works except it has ran out of battery and the charging port no longer works?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@bryan2121 download the hardware maintenance manual for your computer from here That will allow you to evaluate all the damage.
The DC-In jack is actually soldered on the motherboard, you will have to determine if it is broken off or if the solder connections have just tore off. Once you have it apart, post some good pictures of the damage with your question. that way we can see what you see.
Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bryan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 681
