Ir para o conteúdo principal
Repair and disassembly information for Google's Pixel 6 Pro smartphone, released in October 2021. Identified by model number GLUOG, G8VOU, and GF5KQ.
Botched screen replacement with damaged connector
The screen on my pixel 6 pro shattered. I was able to remove it pretty easily, and everything went will until this point. I tried to connect the new screen, and I was having a little trouble attaching the connector. After several attempts, I finally got it to latch on and attempted to turn on the phone. The phone vibrates indicating it's attempting to turn on, but no display.
I took the connector off to look and looking carefully, there appears to be a bent pin. Am I SOL at this point?
https://photos.app.goo.gl/rpBPxqrRkQYQpn... here is a picture of the damaged connector
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
easy repair for most technicians that can micro solder, that could possibly be ground thats damaged which wouldnt stop it from working
por
Adicionar um comentário
1 resposta
I managed to connect it even with the damage and the always on black and white display works, but as soon as it tries to do anything with color the display shuts off. Where can I find someone that could solder a new connector on for me?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Arjun Bhatnagar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 638
