Ir para o conteúdo principal
Why does my washing machine make noise when not in use?
I woke up this morning to a strange noise coming from my laundry room. My washer seemed to be making a noise that sounded like it was slightly running (not agitating or filling with water, just kind of humming). The noise stopped when I unplugged it. But when I tried to turn it on to run a cycle, nothing happened. None of the lights turned on or anything at all. When I plug it back in, the sound starts again after about 5 to 10 seconds.
Update (10/28/23)
The noise seems to be coming from the water drainage hose. It is like it's trying to empty water from the machine but it's not turned on.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hi @moriahmedina,
What is the model number of the washer?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
"The noise stopped when I unplugged it. But when I tried to turn it on to run a cycle, nothing happened." >> you didn't plug it in!
"When I plug it back in, the sound starts again after about 5 to 10 seconds." >> Your water pump may be activating. If anything is activating when it is OFF, that would indicate a defective controller.
Esta resposta foi útil?
Pontuação 2
8 comentários:
I did plug it back in when I tried to run the cycle. I didn't try to turn it on after I had unplugged it.
Thank you so much for the info about the defective controller. I will look into it. Thank you.
por
Did you ever get it fixed? Mines doing exact same thing now
por
@alison86293
por
Most Whirlpool washing machines will have a PCB schematic inside the unit for technician reference. The document should contain info telling you what pins connect to components from the controller. You can use a multimeter to determine if the water pump is activating at the wrong time.
por
Whirlpool has a known issue of washers making noise when off and they are fixing them for free. If you have a whirlpool…call the 800 number
por
Exibir mais 3 comentários
Hi, just yesterday returning to our vacation home we discovered our washer making the same noise immediately after we turned the water back on after being away for 3 weeks. I too have model WTW4816FW3.
Since I couldn't make it stop by pressing buttons I simply unplugged it overnight. This morning I plugged it back in and after about 5 seconds the same buzzing noise started up. There were no control light indicators on, so I pressed the start/reset button for more than 3 seconds and the noise stopped. I'm currently running an empty load to see what happens next, and I will also be calling Whirlpool to check on a fix and/or warranty claim.
Pontuação 0
1- Unplug the washing machine for 10 seconds.
2- Plug it in and wait 10 seconds. It may make the noise again.
3- Press the start button for five seconds and the noise will go away.
4- Wait five seconds and start washing a load as normal.
Pontuação 0
Adicionar a sua resposta
Moriah Medina será eternamente grato(a).
Visualizações:
Últimas 24 horas: 26
Últimos 7 dias: 208
Últimos 30 dias: 795
Ao todo: 9,016
