Ir para o conteúdo principal
Liquidificador portátil recarregável via USB.
Why is it not charging
It is not charging why I don't know but what can I do
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Hi i have the blendjet 2 and its been just 2 months since my impulse buy, barley used and its not charging as well. I think it's because its not properly designed for IP and the water is entering through the usb c port while cleaning. i saw green tarnished copper there and its corroded connector and thus its rendered useless unless we change the port. I will check if i can replace mine. I had contacted blendjet support and they said its out of warranty. wasted my money on this infernal junk (wont even call it a machine)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Priyanka Baheto será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 713
