Ir para o conteúdo principal
A2115 / 2019 / Processadores de 3,0 GHz com 6 núcleos i5, até 3,6 GHz com 8 núcleos i9. Lançado em 19 de março de 2019.
Can I replace Fusion Drive with ssd
so I just bought 2019 27" iMac with 3 ghz 8 core i7 cpu, 16gb ram, 570x 4g vga that is 1tb FD with 28gb(could be 32gb, wrote it 28g cuz thats what system info says) of nvme ssd doing boot ups and cache works with 1tb hdd storing datas.
I'm here to replace it with my 1tb nvme ssd and 2.5" sata ssd which is gonna be pulled out from my previous late 2015 27" imac that contains all the datas stored from my previous machine. red about Fusion Drive being little hassle that it needs to un-fused to get it used right but can't seem to find out any info regarding to that, had to be sure before popping up each of the screen lid for a replacement.
and also, the fresh 1tb hdd that will get pulled off from my 2019 iMac is having plan to be placed at 2015 iMac which was not a fusion drived iMac. my theory on it tells me its fine to do so but would like to be sure on it too. I'll prolly pre-install os Monterey on 2019's 1tb hdd then do the replacements vice versa.
if I'm having to some how un-fuse the Fusion Drive option in 2019 iMac, please let me know how can I approach doing it so. thx!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Yes just use extra 2.5inch ssd
Esta resposta foi útil?
Pontuação 0
1 comentário:
no but my case is that im needing to replace nvme blade ssd and the 2.5 from 2015 into 2019. do i need to split out fusion first to be doing that? or is it just safe to get go replacing?
por
guessing you've already resolved this...
You install both drives & "fuse" them together (I recall doing this in Terminal) - it completely wipes both drives and formats it making it look like a single drive. Then you install macOS to it & macOS manages what to "cache" on yr smaller (and faster) NVMe drive because you use these files often (most likely macOS boot files)
Pontuação 0
Adicionar a sua resposta
e jo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 579
