Ir para o conteúdo principal
A 13-inch "2-in-1" laptop with a 360-degree hinge that allows it to convert to a tablet-like form factor.
How to check hinges cuz not right
How to check the hinges cuz it popped out of place a few days ago
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Esta resposta foi dada inicialmente para uma outra pergunta.
Hi @carol29331
Here's the service manual taken from this support webpage for the laptop that will help.
Go to p.50 to view the necessary pre-requisite steps and then the procedure to remove/replace the display assembly.
On p.51 it shows the hinges. You need to check whether there's a problem on the lid side of the hinge or the base side of the hinge as sometimes the hinges themselves may be OK but they may have either come loose from one side or perhaps the hinge screw mount may be broken, which would require either a new lid or base assembly
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Carol será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 92
