Ir para o conteúdo principal
Guia de reparo e informações de resolução de problemas para o mouse sem fio da Apple com suporte multi-touch. Número de modelo A1657 ou A3204.
Magic Mouse 2 in not connected
When I switch on the Magic Mouse 2... on screen says "Mouse Connected". Few seconds later, on the screen says:" Connection Lost" I'm thinking about the battery of the mouse( 2 years now, non stop working). But the battery is a common on. Thank you in advance for your help. Panagiotis Badalakis
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
While its possible the battery has failed, I would first give the mouse a good over night charge (better than 8 hours) use your iPhone charger as your system likely won't let your mouse charge when in sleep mode.
In any case heres the guide and the battery info Substituição da bateria do Magic Mouse 2
Esta resposta foi útil?
Pontuação 1
2 comentários:
thank you very much, dear dan. i saw that the battery costs about 85$, and the new one round 100$. does it worth it?
por
@panagiotis81413 - For some people that $20 does. For me it’s the principal of throwing away a still functional device when it only needed a battery. We’ve become too throw away wasting resources.
But, before you make that jump make sure the battery is truly bad. Often times it’s just not getting a good charge.
por
Adicionar a sua resposta
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 484
