Ir para o conteúdo principal
Power Supply Replacement Question 17" to 20"
Is it possible to swap in internal "guts" of a iMac 17" power supply into a 20" non-working power supply?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
The Power Supply's are different sizes, a 17" might work in a 20", but definitely not the other way around. when you sad "internal guts" I hope you don't mean actually opening the Power supply..
if incase the big warning that says "DO NOT OPEN, DANGER OF ELECTRICAL SHOCK!" wasn't good enought for ya.. let me say.. DO NOT Open a power supply.. the capacitors store power even when its unplugged.. and we're not looking for "darwin award" nominees here.
Esta resposta foi útil?
Pontuação 1
Thanks - I will not attempt to open. I was also wondering about the bracket that holds the hard drive for a 20" iMac g5. This seems like a tricky part to obatin. Any idea on where I can find this?
Pontuação 0
Adicionar a sua resposta
andrew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 2,861
