How to replace radiator drain petcock valve
drain valve wont turn open and needs to be replaced. How to get old one out and install new valve
Esta é uma boa pergunta?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 56
Hi @dougs57198,
What is the year and engine of the vehicle?
por jayeff
2003 std 5.7 base coupe with 1/4 turn white plastic valve which a sq driver just spins and valve does not open or come outwards. I have done it before OK a few years ago.
por Doug .S
@dougs57198
Not sure if access is easy but can you use a pair of multigrips and try pulling the drain cock out as you're turning it?
por jayeff
will give it a try, but now getting cold and I'm likely to delay for a while. Thanks for replies.
por Doug .S
